Chris_911
My first post so please be gentle :smilewinkgrin:
I am preparing to start our bathroom project. I am a competent DIYer but no professional. The room is roughly 2.1 x 2.1m. The house was built in the early 90s and the upstairs partitions are made from paramount wall boarding. I have drilled some exploratory holes and can find no timber studding - only appears to be timber at the top, bottom and extreme sides. One wall is an external wall with window and this is dry lined.
I have some porcelain tiles, 600x300mm, which weigh in at a whisker under 20kg/m2. These will be fixed with Mapei adhesive.
The bathroom currently contains a bath, toilet & sink. I am adding a shower over the new bath and will be constructing a partition section at the exterior wall end to accommodate the shower gubbins. I intend to construct this from stud woodwork and cover with 20mm Wedi board and tile directly onto this.
It was my intention to cover the existing partition wall alongside the bath with Wedi board and tile straight onto this. However, following my explorations I can see that I have no studwork to fix the Wedi board to. I was intending to use 12.5mm Wedi board.
So I'm left with a dilemma. The bathroom is part-tiled, the rest is painted. My main priority is to ensure that the substrate for tiling is exactly as it needs to be. If this means more work then so be it (I'm currently time rich). The intention is to fully tile the new bathroom.
My current thinking is that I can't tile onto the paramount boarding - weight loading and also no good fixing for the Wedi board. Clearly all the paint needs to be removed in any case. I am leaning towards carefully removing the bathroom side plasterboard skin of the paramount wall board, constructing a stud framework according to Wedi guidelines and then facing this with Wedi board - and tiling straight onto it. I am thinking 12.5mm board for this purpose.
I'd be grateful for any thoughts/guidance on my thinking. My main desire is to do the right job and get a finish that I can be proud of.
Thanks in advance for your help!
