Discuss perfils for large format tiles in the UK Tiling Forum area at TilersForums.com.
Spud
Hi deano
I have only ever used them when fixing porcenalosa tiles they have a 5mm internal corner bisque side and a 20mm external angle on the ceramic face, i have only ever stuck them with spf adhesive using 1mm card as a spacer or red wedges to even the joint if they are slightly mis shaped ,they do look okay when fitted but i found they were not a perfect match to the field tiles when using the travertine effect 900 x 300 tiles, they are easier to fit than mitring the tiles but do need be mitred themselves when meeting 2 externals angles as i have never seen corner pieces as regards fixing you need to cut the adjacent tiles 20mm shorter than the external corner to get the perfil to fit square to the to edge tiles they are meeting
peckers
porcelanosa perfils, and fitted just as gary has described :thumbsup:
Reply to perfils for large format tiles in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
What would you guys do with the walls to prep for fitting 1200mm x 600mm Onice Verde (Porcelain)...
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
