Discuss Plasplug Contractor plus wet saw vs bridge saw in the British & UK Tiling Forum area at TilersForums.com.
Mcluma
Hi,
I have the plasplug contractor plus wet saw, and used it quite a bit, however now i have to cut a lot of 60cm porcelein floortiles
I have done some before on this one, and found you have to push very hard to get these big tiles through it
If I look at arround the Gbp 200 mark what are reasonable bridge/radial saws, or should I stick with the plasplug one
macten
1,158
Nottingham
I'd recommend the QEP bridgesaw from tops for that price range.
Standard blade isn't bad but if you are doing a lot of large format porc then get the 'ultimate' blade for it. Topps won't have a clue what you are on about but if you ring QEP they will give you the ref code and Topps can get you one in. About £50 if I remember rightly.
richard Kent
I got the pro 900 bridge saw from topps and as everyone says it's a bit on the heavy side, that said, it does cut up to 610mm.
I did notice that I got the best cut from the right side of the blade as you pull it towards you, with slight chipping on the off cut on the left hand side.
I did change the blade to Marcrist and this helped a bit, not too sure if it's me or the tile cutter.
The saw comes with a 22.2mm arber so if you want to fit a Marcrist you will need a 30mm to 22.2mm reducing shime, not sure where I got mine but Sir Ramic helped me with that problem.
Reply to Plasplug Contractor plus wet saw vs bridge saw in the British & UK Tiling Forum area at TilersForums.com
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hello lads It was just over 3 years that I have been using my Dewalt tile saw when it got...
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
Hi all. I'm new to the forum and after a bit of advice on a new wet saw. I've read all the...
5K
Hi Guys, I need your help. I just bought my first apartment and I plan to tile my bathroom...
Ceramico tiling
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
