Guest viewing is limited
Discuss plasplugs master tiler in the UK Tiling Forum area at TilersForums.com.
steve9999
Grace'sDad
I use one and it compares well. Nice quiet powerful induction motor. The blade which comes with it is ok but a lot of peeps will be along to tell you to put a marcrist blade on.
My only gripe is that the blade can have a tendancy to wander if you cut slivers with too much pressure. I don't think the spindle is as tough as some of the "professional" cutters.
For £80 though it's a steal. Mine munches through porcelain easily.
(oh, and forget doing mitre cuts - impossible!)
Ric
i used my mastertiler to cut mitres on q rock tiles, wish i hadn't bothered now as the little stand you pull out to get the 45 degree angle snapped!!:mad2: i also put a macrist blade on mine which makes cutting much qiucker but i now get lots of little bits flying up as i cut, is this typical of the macrist blade?
As iam typing this i have been asked to quote for a shower via email, whoopee!
Gazzer
[FONT=Arial, Helvetica, sans-serif]COMPACT PLUS (DWW100)[/FONT]
[FONT=Arial, Helvetica, sans-serif]Flip up guide plate for 45° mitres.
Water re-circulation system for
cleaner results. Assembled ready for use.
80mm general purpose and high glaze
[/FONT]
[FONT=Arial, Helvetica, sans-serif]PRO-TILER PLUS (DWW110)[/FONT]
[FONT=Arial, Helvetica, sans-serif]Flip up guide plate for 22.5º & 45º mitres.
cleaner results. 500w geared motor.
110mm general purpose and high glaze replacement
[/FONT][FONT=Arial, Helvetica, sans-serif]CONTRACTOR PLUS (DWW150)[/FONT]
150mm general purpose and turbo blade replacement
[/FONT]
[FONT=Arial, Helvetica, sans-serif]MASTER TILER (DWW180)[/FONT]
[FONT=Arial, Helvetica, sans-serif]Flip up guide plate for 45º mitres.
cleaner results. 650w geared motor.
180mm general purpose and turbo blade replacement
[/FONT]
Reply to plasplugs master tiler in the UK Tiling Forum area at TilersForums.com
hi all! I wondered if I could get some opinions on somethings? Firstly, I am looking to buy a...
9K
F
My old Vitrex Versatile Power Pro 560 is dying out and I need to replace it but for the life of...
7K
Unbelievable Has anyone come across super fast drying plaster?:mad: I arrived to tile a...
White Room
Hi This is my 1st post in the forum. I have been a tiler for 13 years. I have started my own...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
