plasplugs master tiler
Hi, I bought a Plas Plugs Master tiler machine, I don't like the groove in the table top bits of tile jam in it, it's a pain, the moter isn't powerful enough, if you can afford something better get it.
Thing is the Master tilers only £80 so it's a good cheap cutter, but yeah, the grooves can get clogged, but I've never had a problem with the motor power, though the most I have thrown at it is 8mm porcelain, but that was fine.
Fill the grooves with floor adhesive and rub it down with sandpaper...sorted.
Power !!!well what do you really expect for the price and i have never struggled. Maybe replacing the wheel with a Marcrist and feed through gentle with plenty of water has been my working method.
how long do Marcrist blades last before needing to be replaced. i just want a very rough idea for a tiler working full time. at £50 a pop there not cheap.
just want a very rough estimate for a full time ceramic tiler that also cuts porcelain now and again.
Spent the last week or so plugging away at 9mm porcelain tiles with the Master Tiler. Because they are big tiles, its being used almost constantly. Tried a local tilers dry cutter, but couldn't get the knack and shattered a couple, so back to the wet cutter.
The finish with the stock blade is more than adequate, but you need to take your time. I get soaked as the tiles are too big for the water to run off properly or to use the guide, and the grooves do need cleaning out each time. (think I'll be trying that suggestion of filling the grooves!)
With about 100 tiles on the wall, about 80 are cut and I wondered if I should try a new blade. Bought the turbo blade TDW180 and after a couple of tests took it off and went back to the original. Although the blade goes through the tiles a lot faster, even going slow left the edges badly chipped.
I was almost tempted to give mitring a try, but after the comments above, I don't think so.
I was suffering from the very end of the cut (last cm) breaking away. Using a wooden baton to even the push pressure on either side of the cut reduced this, but now cutting halfway in from each side, and flipping upside down for the final inch or so. Yes I get soaked, but I am more than happy with the final result.
if your going to take this tiling game seriously get a rubi leave the plastic crap to the DIY Er's
I have spent £7-800 in the past on Rubi and Sigma wet cutters.
But now i would rather buy a new 'plastic crap' cutter every year or so, as they are more than good enough for the job.
steve9999,
Dan,
steve9999,
Dan,
