Discuss Plasplugs Pro + spares in the UK Tiling Forum area at TilersForums.com.
doit4u
My Plasplugs Pro + wet cutter has been taking a small chip off the edge of the tile at the end of a cut. I have noticed that there is a slight flutter when the wheel is spinning so I am wondering if this is causing the problem and there is wear in the motor shaft/bearing.
Before I try and strip the machine to have a look does anyone know if internal bits are available or is it a case of chucking it and buying something else.
It might be worth getting in touch with the company (0800 8406820) as I have a contractor plus and burnt out the motor and they said I can get a replacement motor for £25.00 plus shipping.
I do agree though at the lower end you do take a chance with the machines you get. I was really chuffed with mine as I was able to cut marble rods into 5mm thick slices without a problem.
Reply to Plasplugs Pro + spares in the UK Tiling Forum area at TilersForums.com
So I've had my 1200 for a while now and it's done 5-600 cuts, mainly travertine, 610 x 405 x...
25K
Jelthetiler
How do I drill a hole in a steel bath. Or cast iron bath. Instructions on drilling into baths...
16K
Deleted member 1779
F
Hello everyone. I am over here in the USA, but noticed, when googling for info on Mapei grouts...
19K
Mr Tiler
Hi Guy's, been a member a short while since planning a new shower room install. Trying to take...
ive just opened a batch of 600x 400 x 12mm jerusalem gold honed limestone. the face looks as...
jonnyc
TF Group Please Join
Tags
usa
