Discuss Plasterboard /ceramics in the Canada Tile Advice area at TilersForums.com.
I always prime plasterboard!! The issue was that if using a cement adhesive it can react with the calcium in the plasterboard ....the same way that cement adhesive will react with the calcium in anhydrite floor screeds or tapes that aren't alkali resistant. Also the primer will stop the plasterboard from drawing the moisture out of the adhesive and drying it before it can fully cure. This is what I was told anyway.....
If I'm tiling a wet area I won't prime as it will be tanked and the tanking systems i use don't require a primer.
Is there any harm in priming?
Reply to Plasterboard /ceramics in the Canada Tile Advice area at TilersForums.com
