Discuss Plastering advice - large porcelain tiles in the Canada Tile Advice area at TilersForums.com.
Catty
UK
I would be grateful for some help please! Bathroom walls were bonded a few weeks ago but didn't apply skim at the time (long story). Is it too late to skim now? If not, how should the bonding be prepared / sealed prior to applying the skim coat now that some time has passed? I understand that PVA is out! Will be tiling with large porcelain tiles.
On one
If you can swap the porcelain tiles for ceramics you might be able to pull it off without too much hassle.
The Bonding(undercoat) plaster should be brushed or rollered with numerous coats of diluted PVA until it won't absorb anymore (just a case of going round and round the room) Then a final coat of PVa diluted 1:1 ..... when that goes tacky apply your finish plaster.
Obviously your not looking for a paint finish......just a reasonably flat finish
Catty
UK
Thank you everyone. The tiles are 9.5mm thick and weigh 18K per sq. meter, which with adhesive will take them a bit over the recommended load of 20K for plastered solid walls, so will risk that. I appreciate that we can't tile over bonding and will need to add a skim coat. My worry is whether we've left it too long to add the skim coat to the bonding as the bonding was put on a few weeks ago and will have dried out by now. Many have said on this forum that shouldn't use PVA in the bathroom due to the moisture - but would this be OK over a bonding coat before skimming? So, my question is, is there is another product I should put onto the bonding to seal it before skimming or is too late to do anything about it now and have to start again? Can't put up cement board up either as there's not enough room! Urgh!
Andy Allen
1,318
Gloucester
You can't use PVA as a primer before tiling, using PVA on the bonding before applying the skim coat of plaster is fine, wait for the skim coat to dry apply an acyrlic primer then tile...
As for the 2 week gap between the bonding and the skim coat, I'm sure it will be fine, but I'm no spread, but im sure someone else can confirm this.
Waluigi
PVA doesn’t matter on the coat between bonding and skim coat. It’s only unsuitable as a tiling primer.
As already mentioned- lots of coats of your PVA/water solution and really brush it into your bonding. Any gaps and it’ll set the skim coat instantly and it’ll craze. I would lightly brush the skim instead of polishing it.
Boggs
1,118
Uk
Thank you everyone! You've been really helpful. Fingers crossed that my total weight of approx 22K per sq meter (including adhesive) will be OK!
Just remember to take your spacers out. :tearsofjoy:
widler
1,328
England
Hi catty ,being a common plasterer , i can advise you to pva the bonding coat and skim, if your plasterer can’t handle suction.
As long as your tiles are what you say they are in weight, prime with a tile primer and tile .
Id of personally plasterboarded it and tiled, so much easier than a rough coat and skim.
Cheers
Common craig ;)
Reply to Plastering advice - large porcelain tiles in the Canada Tile Advice area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
UK
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
