Discuss Plastering course to help with tiling in the British & UK Tiling Forum area at TilersForums.com.
tysfoot
Am thinking of doing a short plastering course so that i can use it with my tiling. as most walls ive come acriss need some sort of plaster and dot and dab from time to time i was thinking it might be benefical to do a course like this.
What do you think
Has anyone got plastering skills that you use for your tiling
Has anyone done a plastering course, are they worth it ??????????
tysfoot
if a room needs a complete replaster i can make an extra few hundred quid so ill definitley look into it. tiling is all about prep, ive worked on some right bumby walls and ive had to pack the tiles out a lot, dunt half slow you down. that extra skill will come in handy.
wouldnt mind doin a beginners plumbers course but its getting expensive i suppose. all i need to learn is the basics of undersyanding the workng and fittings of sinks baths and toilets.
Does anyone know of a course designed for this
CLAYS TILES
had a look at a few centres near me, they all seem to be 4 day courses for £300.
I think ill only need a two day course max, does anyone know of any othere centres around greater manchester
I'M booking into one in february weekend course,£175, shropshire building skills (.co.uk) if you want all the info m8!
Reply to Plastering course to help with tiling in the British & UK Tiling Forum area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Beginner Tiling Courses 1, 2, 3, 4 and 5 Day Tiling Courses? These are brilliant for a DIY...
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
