Discuss Please help a tiling newbie doing a kitchen floor in the British & UK Tiling Forum area at TilersForums.com.
Z
zoffy
Kitchen floor. Concrete base in a "new build"
40x40cm Vivies Porcelain tiles going down.
1. Please advise on adhesive.
2. For cutting I intend to use the Wickes wet cutter that is on special offer. Will this be up to the job?
Wickes  – Tools, Ladders & Storage – Power Tools – Sawing and Carpentry Tools – 450W Tile Cutting Saw
3. Would a 10mm trowel be the correct size for a 40x40 floor tile?
4. I'm in the Swindon/Chippenham area so a good supplier in that area would be nice to know about.
My first post so don't be hard on me and thanks in advance
K
Kitchens&Tiles
hello mate.
The adhesive depends on what the floor is? if its wood you will need a flexible adhesive, if concrete or screed and ordinary single part adhesive.
Look for a Topps tiles, as they are everywhere locally, and i would recomend either Bal "Goldstar" or "wall and floor professional" try and get a grey colour for darker tiles or a white adhesive for lighter tiles.
A 10mm trail should be fine.
The cutter you linked is a cheap and cheerful only 450w.
It might get you through it but might burn out on porcelain 10-14mm thick
i recommend at least 500w maybe Vitrex as they are quite cheap but ok and look for at least 180mm diameter blade.
Hope this helps
Olz
A good cement based adhesive (bagged powder you mix yourself) suitable for porcelain tiles, check which stores have what stock in your area
Wickes *–*Tools, Ladders & Storage*–*Power Tools*–*Sawing and Carpentry Tools*–*450W Tile Cutting Saw
I would image that the blade wont be designed for porcelain tiles, most likley just ceramic, why not see how much it would cost to hire a suitable cutter from a local hire shop or tile shop.
10mm U notch trowel (solid bed thick bed), such as TradeTiler.Ltd Rubi Stainless Trowels
Sorry cant help you here, try a CTD nearest on to you is;
Ceramic Tile Distributors
Units 5-6 The Paddock
Hambridge Road
Newbury
RG14 5TQ
T:01635 521 197
F:01635 31222
Welcome to the forum. :thumbsup:
J.R Tiling
Hi mate im also in the chippenham area , so your best bet is to go to Topps Tiles wich is on the A4 road just past the big b&q. There is also a Topps in swindon , and a "Tile Store" in Devises
Topps do a "Bal" rapidset powder that i use on most floors (grey or White)
Tile store do a range of Mapie powder but never used it
Hope this helps and if you have any probs or need better directions to Topps then feel free to get in touch :thumbsup:
Reply to Please help a tiling newbie doing a kitchen floor in the British & UK Tiling Forum area at TilersForums.com
I have a small kitchen with a floor area of 265cm x 140cm with the door recess adding another 20...
Hello! Please I need your help. I'm living in a 3yo department on a 5th floor (the entire...
5K
Hi everyone.....im new to the forum and I'm looking for some help and advice please. I tiled a...
6K
Hi all, can anyone help me find these tiles! I recently bought a house and unbeknown to me the...
Jamie e
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
