Discuss Ply floor prep... in the Canada Tile Advice area at TilersForums.com.
Z
zzr-matt
Ive got an 18mm chipboard floor over layed with 18mm ply screwed at 150mm centres. The ply was coated on the back and edges with sbr before installation.
Running a level over the floor some joists are up to 7mm lower than others.
I intend laying 600x300 porcelain tiles over this using granfix cfta slow set adhesive which ia good for a 3 to 6mm bed with up to 12mm in places. I fall within this spec but wonder if I would be better with a levelling compound before starting tiling or maybe skimming the hollows with adhesive first?
Mark S
I would always go with a levelling compound, it's what they are designed for, use a fiber reinforced one to accomodate any flex etc. Prime the boards first, the apply SLC.
I would suggest using 1 manufacturer for the lot, primer, leveller and adhesive, job lot, and back up from manufacturer if needed, they would even provide a spec if you rang tech desk!
Reply to Ply floor prep... in the Canada Tile Advice area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
Ply floor prep...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
