Ply floor prep...
Z
zzr-matt
Ive got an 18mm chipboard floor over layed with 18mm ply screwed at 150mm centres. The ply was coated on the back and edges with sbr before installation.
Running a level over the floor some joists are up to 7mm lower than others.
I intend laying 600x300 porcelain tiles over this using granfix cfta slow set adhesive which ia good for a 3 to 6mm bed with up to 12mm in places. I fall within this spec but wonder if I would be better with a levelling compound before starting tiling or maybe skimming the hollows with adhesive first?
Any recommendations on one to use? I take it just fill the dips and feather out?
Worst joist is 7mm, next one either side is at 4mm out next at 2mm.
Depending whats available in your area, tilemaster is good and Ultra 2 part level....
Deffinitly spend time on the prep as this will make the tiling alot earier!...I tiled a floor that the customer self leveled himself....big mistake lol....learnt not to do that again
I would always go with a levelling compound, it's what they are designed for, use a fiber reinforced one to accomodate any flex etc. Prime the boards first, the apply SLC.
I would suggest using 1 manufacturer for the lot, primer, leveller and adhesive, job lot, and back up from manufacturer if needed, they would even provide a spec if you rang tech desk!
Ply floor prep...
zzr-matt,
Mark S,
zzr-matt,
Mark S,
