Discuss Plyboard thickness in the British & UK Tiling Forum area at TilersForums.com.
Time's Ran Out
I would persume the chip board is on the joists,I would say the floor is solid enough.
Rodders - I think you will have to check the sub floor to see if it is on joists or is a floating floor!
If it is on joists - secure - and no movement -you can overboard it with anything from BS minimum thickness plywood to 6mm hardie backer boards.
Reply to Plyboard thickness in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Plyboard thickness
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
