Plywood or Hardiebacker or NoMorePly
Is it always nesessary to put the 6mm boards down with both adhesive and screws? I always thought it was but the guy in my local tile shop swears you can just screw them down If the underlying floor is good?
3mm perimeter yes.
I was ridiculed once by an employed very quick but rough tiler for using adhesive under them, he left fully thinking he was right.
Adhesive every time for me, it won't get my home at 4:00pm like him though.
Thanks for all the excellent advice lads.
This might seem like a daft question but do I put the cement board straight on top of existing floor and does this take the place of ply.
Sorry for the ignorance
ATB
Col
Hello Lads,
I would appreciate your professional advice.
It has been suggested that I use ply and put Ditra on top.
I have tested the floor with a lazer level and there does not appear to be any deflection. I found some info in old posts about L360 code and have worked the maximun deflection to be around L500 and the allowed deflection is L360 so all looks good.
Do you think ply and Ditra is over the top as there is little deflection and should I stick with Hardi or No More Ply.
Any help is appreciated
ATB
Col
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
