Discuss Plywood over floorboards in the UK Tiling Forum area at TilersForums.com.
The tiles are 200x400. The floor is quite small. About 4 square metres. The whole job is 13 metres square. All walls are solid brick. So do i dot and dab aqua board onto those?
So, if i wanted to remove the floorboard, i would have to put 18mm ply, and then the cement boards on top of those? But then, this would be pretty much the same height as the original floorboards any way wouldn't it.
Your mimimum tile backerboard overlay on T&G boards or chipboard / plywood would be 10mm, standard flexi adhesives offer no guarantee if any less.
Reply to Plywood over floorboards in the UK Tiling Forum area at TilersForums.com
