Discuss Pointing brick slips in the UK Tiling Forum area at TilersForums.com.
A giant version of an icing bag BIGGER THAN IT LOOKS 600 mm long x 350 mm wide
Very controllable flow, quick to refill and easy to clean
10 mm hole in the end - You can insert a normal siliconong nozel first for fine joints
weight 200 g
Price: £3.99 £4.79 Including VAT at 20%
Hello all first post. How wide are the joints, normal brickwork 10mm?
Thank mate but it's all I do nowadays it does work yes but have specialist guns nowadays you would not believe how quick they are compared with the rest but keep it to myself as my main competitors copy me and try to undercut me everywhere I goI use a easy point gun from screwfix , we fill it with an empty 1ltr milk plastic bottle with half the bottom cut off. Works a treat, but if useing sand and cement you need to add some feb mix and whisk well. Tap the barrel empty before reloading. I used to repoint loads in a past life and find the gun great for grouting large tiles.
I can't find such a thing as a easy point gunI use a easy point gun from screwfix , we fill it with an empty 1ltr milk plastic bottle with half the bottom cut off. Works a treat, but if useing sand and cement you need to add some feb mix and whisk well. Tap the barrel empty before reloading. I used to repoint loads in a past life and find the gun great for grouting large tiles.
Yes I have seen it and the tools been looking at them it the states this weeki was taught by and old school builder years ago how to do tuck pointing this decades before patent mortar injection devices thin mortar joints were tackled with thin jointing tools some probably 5mm wide the tools were flat blades with a wooden handle it takes patience but results look good
yes theres two i have found and yes dosent mater how much bricklayers say they can point in a day i am on my 4th house lolAmerican tuck pointing tools are not the same as the tuck pointer Cozy is on about but is what i use for pointing combined with a large pointing tray ive never come across a gun which can do it as quick but would be interested if there is one out there, ime not competition pjc
Reply to Pointing brick slips in the UK Tiling Forum area at TilersForums.com
