polished marble tiles over plywood
same as just get it lot cheaper get it delivered just fix it with adhesive no screws on the floor:hurray:
Me personally would still put in a few screws in on timber floors....best just to make sure.....( only after adhesive has set )........
thanks to you all, all i need now is a decent plumber! had 5/6 out and the rubbish they spout!and the cost, they quote 250-300 a day labour, wished i earned that.
Yes pete..forgot to mention washers... :whatchutalkingabout .............:grin:
hi puzzled would you like to register as a member then we have a name and you can come back for more info..you will only be allowed so many posts as a guest...:thumbsup:
How much..!!! did they look like theres two John 'swift nick'Nevison
Claud Du Vall
Grumpy i use 10mm PCI backer boards i think its easy and better than ply did use ply for twenty years this is a much better way nowadays you can get it over the wall :lol:
http://www.pci-uk.com/PCIUK/En/products/intermediate_substrates/Construction+Boards/pecidur__pecidur_creativ.htm
Still have the same availability problem up here Pete. Only place i have found any backer board is Topps - Hardiebacker - and it isn't cheap in comparison to ply. Have to say though it is very easy to cut with a saw.
Grumpy
Grumpy what does it cost you for a sheet of 12 & 18mm ply up there ?
puzzled,
GazTech,
puzzled,
GazTech,
