Discuss Polypipe ufh in the British & UK Tiling Forum area at TilersForums.com.
K
kaharrison9
Couple of pics here shame i didn't take from day one.
To another question i used an S1 for the ditra(6mm trowel) and the tiles.
Thespanishtiler
Hi Phil.
Have just recently tiled just under 70sm of porcelain on the polypipe overlay system.
Polypipe simply say tile directly on top which i've now rang them on 3 seperate occasions over 2 years asking if technically there was anybody to speak to about this advice. Problem i had was trying to explain the possible failures that could occur going direct when the plumber is reciting Polypipes advice of going direct to the customer.
Anyway i screwed it all down rather than leaving it floating.Also screwed the black ends that the pipes turn in as thats where the most movement i found was.Used turbogold as pulls everything tight.
Then checked with polypipe and the panels are gypsum so have to to be primed correctly.
Spoke to the Ultra rep and asked if it should be treated as an annhydrite screed and he's advice was bear it in mind but as it wasn't a screed to give a good vaccum then prime with ultra it fp.First 5-1 then 3-1 when dry.
Used the 2 part ultra level as thought latex would be better for keying to the panels.
Then went over with Ditra.
The heating after 2 weeks is gradually been brought up and the heating had been on before instalation as the plumber has to check the systems fine for him.
Fingers crossed
Kev
Kev mate
You forgot to mention ringing me forty times or more to bend my ear over the latest advice you had got !!!!!! Ha Ha
Job looks mint my friend
Rob
Daz
I'm gonna resurrect this thread -Soz!
One of my Architect clients asked me to tile onto this system today :mad2:.
I will have to fit 450mm square porcelain into "zoned" areas - plenty of expansion gaps :thumbsup:.
Am I correct to insist screw the fibre boards to the screed and then slc over. Is the decoupler a necessity or option?
Cheers,
Daz
Reply to Polypipe ufh in the British & UK Tiling Forum area at TilersForums.com
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
We're quoting to rip up and replace a tiled floor with Limestone tiles. I'm looking for advice...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Hi Newbie here (DIY - small jobs only!) Need to get a pro in to do a floor (35m2 or so...
Polypipe ufh
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
