I’m with Boggs , if that’s a 21 grand kitchen fit, can we look at the rest , cos the painting looks ***** as well 🙄😳
hopefully that just a base coat because if it isn't christ your right Wilder it's the mayor's favorite saying from the wire "shiteeeeee"
That is not good, top should be mitred , also when fitting ,the back of the trim should be cut back so trims don’t over lap and go flat to the wallKitchen fitter used charcoal rather than grey grout which probably makes this look worse, but to my eye the edging is not well done with gaps and sharp ends, the grouting is uneven and several tiles are poorly shaped. Can this be rescued? Am I being too fussy here?
Absolute garbageKitchen fitter used charcoal rather than grey grout which probably makes this look worse, but to my eye the edging is not well done with gaps and sharp ends, the grouting is uneven and several tiles are poorly shaped. Can this be rescued? Am I being too fussy here?
