Discuss porcelain base pics in the British & UK Tiling Forum area at TilersForums.com.
Q
quick draw macgraw
Hi all,
uploaded some pics of the base for 400x400 porcelain tiles from new concrete screed to some sort of tile which i was wondering if i could tile straight onto they are quite thick as there is a hole in one of the corners and they must be at least 20mm thick but the floor is solid with no visible movement. I realise i need movement joint where two floors meet but what other things to take into consideration, there is a slight height variation between the two but its not stepped its more like a radius and was thinking of just back skimmimg those tiles then levelling off again.
Any info welcome
Cheers Steve.
DHTiling
HERE'S STEVES PICS IT WILL HELP TO SEE THEM SO YOU CAN HELP HIM OUT....
DHTiling
They are quarry tiles steve.....if that is just a crack in the floor then this is the perfect job to use ditra on...but if it is two separate floors then an expansion joint will be needed but you can still use ditra but install the joint within the ditra as well...but one thing to check first though is that those old tiles are well fixed..because they used to be just laid on a sand/cement screed and but jointed, so check for loose tiles first....the ditra will accommodate the cracks in the substrate etc....transferring to the tiles...
Reply to porcelain base pics in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Hi guys, had some great advice here before so thought I would ask here for advice again...
porcelain base pics
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
