Discuss Porcelain floor tiles on plywood in the Best Floor Tiles area at TilersForums.com.
Raz
Hi,
I'm looking to get commercial premises tiled with porcelain. The building is currently a shell with new flooring to go in. I have been advised to go with 22mm chipboard with 15mm plywood on top. In terms of primer and adhesive I have been advised that the plywood should be primed on the underside and the edges with Mapei primer g and Mapei keraquick should be used as adhesive.
Can someone please clarify if the above is the best solution for an area of approx 400 sq.m.
Also can Mapei keraquick be used on plywood?
Alan.P
The downside is that the floor could / will fail due to ingress of moisture causing the ply to de-laminate, excessive movement due to expansion and or contraction or deflection ( bounce ) witch will cause tile and grout failure.
YES, we used to tile to ply and YES it worked, not always though, there are horror stories on these forums that will attest to that, if your going to do the job right, and it sounds as if you want to, then listen to the guys, they are some of the best fixers in the country :D
Alan.P
In terms of hardie, can you apply it with screws only
The reason for using adhesive under the Hardie is to take out any irregularities in the substrate, so that the Hardie has complete contact with the floor.
It's not used to fix it down, the screws do that job.
Note....use an alternative screw not the Hardie ones. Turbo Gold from Screwfix are popular.
will 6mm hardie be sufficient.
The thickness of Hardie on the floor is irrelevant.
All it's designed to do is give u an inert substrate to tile to, that is to say,
one that will not expand and contract due to temperature change and or moisture ingress.
6mm is completely fine. It has pre marked screw positions and they will need countersinking.
what do you guys think of applying hardie straight onto 22mm chipboard
Having that we have now established this is a high traffic area, as has been said by @AliGage and @Alan.P a heavier ply would be more suitable.
Reply to Porcelain floor tiles on plywood in the Best Floor Tiles area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Best Floor Tiles
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
