Discuss Porcelain tiles not sticking to plywood? in the Canada Tile Advice area at TilersForums.com.
Webber set SPF rapid primed with webber pr360 / water 5:1 ratio... Everyone is different though. Some on here would not even tile on to plyWhat would you use to fix porcelain tiles to ply?
Not necessarily ? Does the floor feel solid? What thickness of ply is currently down? Are you a pro tiler or DIY project?
15mm ply screw fixed at 300mm centres, as per BAL advice. Ply is fitted over original 22mm chipboard floor. I'm a DIY tiler, but done a few floor tiling jobs in the house and never had a problem. Just worried about try to refix them to ply and having the same problem again?
You still haven't clarified about this chipboard floor.. Is it floating, or suspended? 300mm centres are too far apart anyway.. At the very least, I'd be adding more screws.
Reply to Porcelain tiles not sticking to plywood? in the Canada Tile Advice area at TilersForums.com
