X
xelaris
it might not be "wax" as such but surely there are plentiful of chemicals/polishes out there which could be used to apply a cosmetic layer on defective tiles....the tiles looked perfect before the Swarfega - if anything the Swarfega showed the "true colour" of the tiles (can't blame it on Swarfega but on a dogdy seller?)
Thanks a lot for bothering...I've just checked the PH scale myself - all values above 7 are for bases (alkaline) substances... values around 7-9 are pretty common - then I wonder what happens if a drop of lemon (PH2) hits these tiles?!
Then, all this stories about porcelain being such a tough material? A bit of Swarfega and these fabulous tiles look like have been aged by 20 odd years in a few seconds of Swarfega wiping? (not even scrubbing as such and no abrasive sponge involved). I find it very hard to blame the Swarfega alone - maybe a combination of factors - e.g. the Swarfega + Microflex grout....or something else.
Unfortunately, I'll have to postpone the alkaline solution cleaning as there are still more work to be completed and the floor corners haven't been sealed (silicone along the perimeter)...if that Heavy duty pro cleaning fails, I will definitely consider using some polishing/tinting solutions.
