Discuss Porcelain tiles in the British & UK Tiling Forum area at TilersForums.com.
dock
Hi Ferdon
If its a first floor shower and the client is not up to paying for the tanking he's not going to be too happy when water leaks through and statistically there's a fair chance it will dependant on usage. Tiles themselves cannot be guaranteed watertight even where epoxy grout is used. You could then price for remedial works!!!!!. The lads have a point with timber!!
To be sucessful;
1 secure plasterboard to provide a rigid and stable structure.
2 prime with primer G.
3 treat with Mapegum WPS to tank installation, use Mapeband at internal vertical corners and junction of wall and floor.
4 fix in Keraflex Maxi, and S1 classified flexible adhesive. Do not use tub adhesive
5 grout with Ulracolor Plus (26 colours)
6 fill internal corners and junction of floor and wall with Mapesil AC colour to match grout.
Best of luck whatever you use but above with good workmanship will give great result!!
dock
Deleted member 1779
Dont forget your all in one solution for fixings
At £49.99 its value for money even if you dont use all the sizes.
Deleted member 1779
Thats ok!
Postage is £2.99 if you want basic 2day. £8.95 if you want it emergency.
We price compare with Screwfix. Their PP is free on spend over £50.
Our All-in-one kit works out at £52.98 delivered.
Screwfix works out at £120.44 (but you get free delivery)
With us you save over £70.....
We use their part numbers for you to price check
Screwfix Part and id code BFKMX
35mm [code 73491]£34.99 40mm
30mm [code 72062]£30.99 30mm
16.5mm [code 64976]£18.49 16mm
8mm [code 41877]£9.99 8mm
6mm [code 87575]£7.99 6mm
Drill plate Not included Drill plate Included free
Delivery
Free Delivery£2.99
Total screwfix price: £120.43*
Total 365Drills Price £52.98
*prices correct at time of issue - Catalogue 91 used to compare pricing
Reply to Porcelain tiles in the British & UK Tiling Forum area at TilersForums.com
Porcelain tiles
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
