Gazzer
Johnryan - thanks for your reply. Could you be more specific about your concerns ref. bonding the tiles straight onto plywood? Do you think the plywood will be unable to take the weight??, or is the bond itself not strong enough? I used ply because I had a large stock from a previous building job; it's 12mm WBP - and I used it on an ensuite bathroom (with tiling bonded) about 5 years ago - no problems as yet! I'm planning to apply an acrylic primer onto the plywood before tiling. Would appreciate your further thoughts.....
The back and edges of the ply should have been primed, usually the adhesive manufacturer states that it is not needed to prime the face. Also technically 15mm WBP is min spec.
