W weesammy Jun 17, 2008 #1 lookin some tips on layin 600x600 porcelain tiles.walls and floor to be tiled with grout lining up.is it better to lay floor 1st or both together.?any tips welcome:mad2:
H hillhead Jun 17, 2008 #2 I find it a lot easier to tile the floor first,then use 6' level and draw vertical lines up wall from floor joint!!
M mz30 Jun 17, 2008 #3 A lot of people will say lay the floor first(and are probably right),i personally do the walls first,after setting it all out correctly(obviously)
D DHTiling Jun 17, 2008 #4 It can be done both ways.....just down to preference IMO....i do it both ways just depends on job really........
T tiler burden Jun 17, 2008 #5 wall or floor, either way there'll be a compromise somewhere, just depends on what you consider your setting out priorities to be?
G Gazzer Jun 19, 2008 #7 I prefer doing the floor 1st but i would make sure the walls were set out at the same time.
S Spirit Jun 19, 2008 #8 I would set out both the walls and floor. The one that I would start on would depend on how the setting out worked and what type of tile I was using. With 600 x 600 porcelain, I would be more inclined to start with the floor.
