sludd
Hi Guys
I'm refitting my en-suite and have ripped out the existing plasterboard in the shower cubicle. The tiles I am using are 400x400 porcelain and I wonder about using exterior grade plywood instead of plasterboard. The reasons are in case I need to change the tiles in the future without the wall disintegrating and also to get a solid fix into the stud, given the weight of the tiles...
My question is whether this is likely to be OK and will the tiles adhere to exterior ply (as they do on a floor) - if so, what adhesive is best and should I prepare the plywood in any way beforehand.
If not, is standard "green" plasterboard OK and again, what prep (is tanking still required or should I use a primer) and adhesive is best.
I've had lots of experience of porcelain floor tiling without any issues, but not yet on walls...
