Discuss Premium travatine on retro-fit ufh in the Canada Tile Advice area at TilersForums.com.
Midlandceramics
This is a retro fit ufh which lays on exsisting sub floor ! Becouse it's a refurb and they don't want sub floor up ! Height is a prob for builder for what goes on top ! Prob for me is I only do things properly ! The floor suppliers tech say just to put 10mm ply on top and screw. I wouldn't use less than 15mm min and screw 300mm! I've done plenty of ufh wet and elec ! But first time on retro ! And with it being travatine . There's some weight on it ! I read the spec through on there website and it read for a lightweight covering , ie. carpet, laminate. Lino ! But does read somewhere in it about tiles can be used ceramic , porcelain and slate !! It has a 10% compression ? And operates at 60 degrees ! I've never had any problems with wet underfloor heating but it has always been in the screed ! Has anyone used this retro fit , speed -fit .and what did they use to go over the pipe mats which are a thermal composite 15mm with a alli covering which the pipes are laid into it's recess
Reply to Premium travatine on retro-fit ufh in the Canada Tile Advice area at TilersForums.com
gamer1
  • Sticky
Hi everyone I need some advice from the collective mind. I've tiled a kitchen floor which has...
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
    Votes: 5 4.1%
    Votes: 11 9.1%
    Votes: 7 5.8%
    Votes: 33 27.3%
    Votes: 16 13.2%
    Votes: 31 25.6%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.7%
    Votes: 18 14.9%
    Votes: 13 10.7%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
