Discuss Premixed grouts.. in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Be Weary of Taking Shortcuts.
Premixed tile products are often marketed to the do-it-yourselfer as a no mess, no hassle alternative to conventional cementitous tile grouts.
Premixed grouts have extended drying times and may not harden for days or even weeks after the tile installation is complete. This is because premixed products rely on both evaporation and the tile and substrate to wick or pull the moisture from the product allowing it to slowly harden. Cementitious grout will harden within 24 hours and fully cure within 30 days. Cement hardens through a chemical reaction (hydration) that bonds water molecules to the cement mixture. Avoid using premixed grout products altogether.
Cementitous grouts do require more effort to mix, however, cement has proven itself both reliable and durable over a period of thousands of years. Cementitous grout is much less expensive than premixed grouts.
.........dave..
GazTech
Topps only supply pre-mix products in very small quantity,for the quick fix solution(solid given time to cure)..I have many a time had to remove tiles fixed with pre-mix stuff,and my god its rock hard and fairly impregnible.These adhesives are not mass produced in quantity..because they would not be affordable..IMO...Gaz
Reply to Premixed grouts.. in the British & UK Tiling Forum area at TilersForums.com
So after a couple of weeks trialing @ISOMAT UK products, thought it was time to give initial...
9K
6K
Be the Best with BAL! The importance of correct training should never be underestimated. As the...
8K
All, This isn't a query, just a brief summary of a situation I got myself into which you might...
6K
Concrete guy
Premixed grouts..
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
