Preparing floor for Lino
Hey guys,
Sorry, not tiles, but I'm going to fit some lino in the bathroom.
I've straightened the floor with 6mm plywood. Do I need to worry about the seams between plywood sheets? I dont want these to be visible above the lino.
How do I fill the gaps around the toilet and sink pedestal etc?
Thanks in advance
ES
You could level it with a 2 part levelling compound like arditex na or ultra level 2 to get rid of holes around toilet etc and also covers board joints or use ardex feather finish , fill joints and screw heads and around toilet then rub down
Thanks fella
I've got a ton of sand, cement, pva etc.
I don't suppose any of this could be used could it? Only need about a cups worth of filler.
If not, I'll go out to the shops this weekend and go with one of your recommendations.
Cheers
Your obsessed with sand and cement . No it's not any use not is your pva for priming the boards if you decide to level it .
EatingSnakes,
Dumbo,
EatingSnakes,
Dumbo,
