Discuss prepping a new selfing screeded floor ready fo porcelain tiles in the British & UK Tiling Forum area at TilersForums.com.
jonnie p
Hi there to all you pro tilers, please can I have some advice, I have an area of 60m in total to tile. I have put down under floor heating (water)and then approx 60mm thick of liquid self leveling screed which has been down about 8 weeks. The underfloor heating has been on for 2 weeks and the floor looks dry. How can I be sure the floor is fully dry, what floor sealant/primer should be used. Does the underfloor heating have to be on or off when tiling any advice will be appreciated
Regards Jonnie p :smilewinkgrin:
Bristol Tilers
sounds fully dry to me, we normally quote 6 weeks. you could always prime it with unibond 6-1 water, to be sure but not really worth it, but you must use a flexible 1 part mix adhesive and matching grout, youll need about 13-14 bags at 20kg, and if you pay more than XX pounds a bag youre being ripped off, DONT use Topps Tiles. Hope thats of help
Time's Ran Out
I think that the OP should read some of the earlier threads on this type of screed (Calcium Sulphate) and take note of the correct method of priming and preparing the surface prior to tiling.
Unless tilers have an in depth knowledge of this product, to advise/suggest/comment without experience could mislead.
Ajax123
1,213
Lincolnshire
Aaaaaaaaarrrrrgggghhhhhh!!!!!!!!!!
Creative Impressions or Nicobond adhesives specifically for gypsum based screeds. Alpha Hemi Hydrate is one of the three types of gypsum based screeds. Prep and priming is the same for them all. Lightly sand to remove any loose debris on top, vaccuum up any dust, prime if necessary with an appropriate acrylic primer (the two above adhesive manufacturers will give guidance on primers) then tile.
drying rate is 1mm per day for the first 40mm depth and then add 2 days per mm for each mm over 40mm i.e. 50mm screed takes 60 days based on good drying conditions. we have had very poor drying conditions for the last 8 weeks or so. The heating will help but it is dependent on temperatures and humidities. The only way to be sure is to test it with a hygrometer. (requires investment of approx £80)
jonnie p
Thanks Ajax123,
I managed to borrow a Tramex cmex meter which gave back readings of 2 for moisture content of the floor which I have been told is ok to tile on. The floor is heated at night with a industial de humidifer going and during the day fully ventilated with doors and windows open which gives a steady breeze over the screed this seems to be working very well, not sure if this the correct method.
I am thinking of using Mapei Primer G ?
Ajax123
1,213
Lincolnshire
dehumidifier - close the windows......
no dehumidifier open the windows.......
the primer becomes largely irrelevent if you choose a gypsum based tile adhesive but if you have decided on cement the primer is the most critical part. Primer G i beleive needs to be diluted for the first coat 1:1 with water and the second coat neat. Make sure you get a written method from the manufacturer and follow it to the letter.
Reply to prepping a new selfing screeded floor ready fo porcelain tiles in the British & UK Tiling Forum area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
