Discuss Primer for UFH screed help in the British & UK Tiling Forum area at TilersForums.com.
mickeysparks
Hi,
just joined and being getting lots of info on tiles and tiling, thank you everyone, good site.
I have built an extension that has UFH installed and a poured (like melted icecream) screed.
What would you recommend priming it with prior to tiling and what kind of adhesive for porcelian tiles (B&Q) 600mmx600mm?
I'm humming and haring over it and would appreciate some guidance.
Thank you.
mickeysparks
Thanks guys for the welcome, the floor screed went in like a yellowish sloppy concrete mix. For some reason I can't find the contractor who done it (driving me mad) The screen has gone off and looks similar to a conventional screed. It wasn't one of the more expensive kind that has all sorts of additives.
Is that any help??
Thanks, mickeysparks
Ajax123
1,213
Lincolnshire
sounds like anhydrite but I want to check as you say it looks like conventional screed. This indicates it could be a flowing cement based screed rather than anhydrite. If you can find out what lorries it was delivered on or if the surface feels waxy....scratch it with your fingernail and see if there is a wax coating on top.......this will be a curing agent which was sprayed on after the scree was laid and will tell me which type it is.
regardless of screed type prep will be similar but the adhesive choice may differ.......
welcome by the way...
Reply to Primer for UFH screed help in the British & UK Tiling Forum area at TilersForums.com
Hi folks, We're having our downstairs tiles installed soon, about 82m2 of 1.2x1.2m square...
Hi folks, Just looked at a conservatory tiling job. Wet UFH system, set into sand and cement...
Hello all. I've got a question for people who know better on what to do with my floor. I thought...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
