Discuss primer on slc in the British & UK Tiling Forum area at TilersForums.com.
Aston
as above
it all depends on the slc and adhesive being used. ie cement based, latex modified, anhydrate etc etc.
if its cement based and if its freshly laid then no BUT if its been down a while and dry as a bone, then it may be necessary.
just make sure its dust free and clean then brush a little bit of water on it and see how fast it absorbs. the last thing you want is the life being sucked out your adhesive before it had time to react properly.
Reply to primer on slc in the British & UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
primer on slc
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
