Discuss primer in the British & UK Tiling Forum area at TilersForums.com.
F
falkirktiler
Hi all, went and looked at another bathroom and the guy has removed some tiles and repaired the wall. I know i will have to prime the new plaster after it's had plenty of time to thoroughly dry out but the rest of the room is just painted. I checked the paint all round and it's sound so do I still need to prime the painted areas before tiling?
Cheers.......Scott......
F
Fekin
Really you want to remove as much paint as possible first as once your new tiles are on, their basically only stuck to a fine layer of paint, and not the actual wall substrat.
If you can't remove the paint for whatever reason, then give it a right good going over with a corse sand paper, then you could prime to give some extra stick, then tile away.
Reply to primer in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
primer
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
