Discuss Primerfor plywood - where from...help? in the British & UK Tiling Forum area at TilersForums.com.
STEVEROG
I am trying to find a source for a primer/sealer to use on the back and edges of the plywood floor I will be tiling onto.
Bal APD and Bal Bond SBR were recommended in earlier posts.
I have found these on line but the cost of £37 for 5 litres seems a bit excessive to me.
I only need enough for very small en-suite bathroom floor measuring approximately 2.5m x 1m
Can I get the BAL products or an equivalent at a better price? if so where.
Steve
DHTiling
Don't buy the BAL one too much pennies..
Tradetiler sells SBR.....
SBR Bonding/Admix agent - (Everbuild)
(Do not be tempted to use cheaper PVA which moisture breaks down)
SBR Bond is a latex based - Highly suited for priming areas before tiling
Water resistant bonding/priming agent and admixture for use in areas subject to humidity, dampness and continuous water contact
Improves water resistance of cement mixtures by forming a reinforcing polymer that increases long term durability and flexibility of the mix on renderings and floor screeds adhesive etc.
Can be diluted up to 3:1 with water - follow instuction on bottle
Price: £11.99 £13.79 Including VAT at 15%
grumpygrouter
sorry to jump on this, I am tiling an en-suite floor and have screwed down 4sqm of ply onto floorboards without first priming the underside. Why should you seal the underside please, looks like I may have to lift the lot?
You should seal the underside and edges to keep out moisture as Whitebeam says. This reduces the possibity of the timber reacting to atmospheric changes giving rise to expansion/contraction issue.
Reply to Primerfor plywood - where from...help? in the British & UK Tiling Forum area at TilersForums.com
As an introduction, I'm a DIY home owner who has gutted the bathroom in a house built in 1980...
Tony R
Hello all, Can any experts give me some advice please. I have a single brick detached garage...
6K
Time's Ran Out
Hello, i posted this in adhesive forum yesterday but only got one reply so i thought i would try...
Hi Apologies for what i'm sure is a pretty obvious question: I'm about to do my second ever...
6K
Simon benn Leeds
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
