Discuss Priming and laying No more ply in the Canada Tile Advice area at TilersForums.com.
Of the new NMP boards, which side comes already primed? The smooth side or the rougher side?
Is it necessary to prime the side facing down before using the mega strength adhesive? I expect the megastrength would bond better to a porous surface so I think better to fit the non primed surface facing down. Am i right?
andreas
178
hereford
The smooth side of 6mm boards(thicker boards aren't primed at all) comes pre primed,however I always prime it once again , it seems to be absorbing moisture a bit too quickly anyway ,no need to prime other side when using megastrengh , the rough side needs priming when You lay it down with tile adhesive.
Reply to Priming and laying No more ply in the Canada Tile Advice area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
Hi, I bought 6mm No More Ply for my bathroom floor before I tile. As you can see the...
8K
Hello I'm a DIYer so apologies if I get the terminology wrong etc I've started work remodeling...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
