Discuss Priming Brick For Mapei Keraquick Adhesive (Jackoboard) in the Tile Adhesive and Grout Advice area at TilersForums.com.
Hi,
I'm currently working on a bathroom and have stripped the walls back to brickwork with lime mortar. For the shower area my plan is to dot and dab 20mm Jackoboard onto the brickwork with Mapei Keraquick before tiling. Does the brickwork need priming for the Keraquick? I understand PVA shouldn't be used with cement based adhesives so if it does need priming what product should I use?
Thanks,
Oscar
macten
1,158
Nottingham
Yes needs priming so use an acrylic based primer. Best to use Mapei primer g if using keraquick. Once gone off I’d recommend screwing (+jackoboard washers). If you’ve got the space I’d opt for battening out and screwing to that rather than sticking to block work with adhesive.
Hi Macten, sorry for the slow response and thanks for your reply, I've gone for Primer G and it seems to have worked well for binding all the dusty mortar together leaving a clean surface for the adhesive. Going to stick with D&Ding the Keraquick as I haven't got the space for battening the wall out. Thanks again for the help.
Reply to Priming Brick For Mapei Keraquick Adhesive (Jackoboard) in the Tile Adhesive and Grout Advice area at TilersForums.com
I'm having a nightmare trying to establish product info from distributors. For example...
    • Friendly
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Hi, I'm retiling the walls in the pictures which is a shower above a bath - one wall is stripped...
Tile Adhesive Trending Topics
London
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
