Discuss Priming Plywood in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi Guys
Recently been reading posts about plying out which recommends priming the back and sides of the plywood. Can anyone tell me why - thanks.
Best Wishes
Howard:ninja:
Lets not confuse the phrase "priming" with "sealing". BAL recommend SEALING the back and edges of ply with BAL BOND SBR. It just so happens that this product can also be used as a primer. Ardex on the other hand recommend using polyurethane varnish for sealing the back and edges. Don't think this can be used as a primer though.........priming as far as I am away is preparing something to accept another coating/finish on the top.
As always, I am happy to be corrected if peeps think otherwise.
bathroomboy
I'm not advising anyone to do this but I took up my own bathroom floor on Friday after it,s been down for 15 yrs and what a job it was, the tiles were so well bonded a 6x4 piece came up after a lot of grunting and groaning from 2 of us and the tiles were intact on the ply.
I remember screwing it down at 150m/m centres and priming it with neat pva on it's face nothing on the back (I know before anyone jumps in I now use acrilic primer in accordance with the manufacturor) I just hope all the floors I am doing now are bonded as well.
As far as I can remember the adhesive I used was evostik tile on wood, not something I would use now, but it did the job well as the tiles were really difficult to remove even with a large sds and armeg tile removing bit, gave up in the end and reverted to levering the ply up.
:beatdeadhorse5:
Reply to Priming Plywood in the British & UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Priming Plywood
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
