Discuss Priming - your views in the Canada Tile Advice area at TilersForums.com.
Dan
Admin
Staff member
5,092
1,323
Staffordshire, UK
Many will say prime everything you can, but IMO you're creating an extra layer that could fail if you're using it just on everything.
Plaster and Cement don't mix. So you need a good quality primer there to create a layer that's stopping the two from touching each other.
Other than that it's usually down to the products you're using and whether they say they need it.
You can obviously help keep a dusty floor free from dust if you clean it then prime it, but generally if you just sprinkle a bit of water on it after a good sweep you'll do the same and not create an extra layer there.
Just IMO of course.
Reply to Priming - your views in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Article
I can personally recommend UK Pro Tiling. Darren is a great tutor, the aftercare is great and it...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
