Discuss Problem with paramount wall board :-( in the British & UK Tiling Forum area at TilersForums.com.
Mark B
Hello,
I have just started a job and have discovered that the internal walls for the alcove shower I'm retiling are made from Paramount wall board - the house is only 6 or 7 years old.
The problem I have is that the alcove is constructed to the right size, 1200 x 800. If I were to try and tile over the existing tiles it would make it too small for the shower tray and screen. I have already started to remove some of the tiles from the paramount and whilst the first few came off OK the next few have removed large amounts of plaster with them.
I'm thinking of talking to the customer about getting a plasterer in but what would you advise?
Mark
Mark B
Hi Grumpy,
It's a partition board system that's a cardboard core sandwiched between 2 layers of plasterboard. I believe it has wooden battens around the edges of each "sheet" for fixing it to the floor and ceiling joists.
I know others on here have had problems with it. I've read through all of the threads and posts I could find.
Mark.
White Room
grumpy, It's two sheets of plasterboard and like an egg box effect sandwiched between the two sheets, It was fast track internal wall construction but only 50mm thick. Don't think they make it any more last time I saw it being used was 30 years ago, surprised at 6-7 years. Answer, Why don't take the bottom tiles of the wall so the tray can fit and build up where the tiles where taken off to the tray then tile over the existing.
wetdec
Hi
Paramount never ceased to be used in France where door frames are made to accept it.
When Lafarge came over here they brought it with them, not sure if Knauff do it as well.
If what whitebeam says is of no use, take the tiles off best you can and then patch the board with multi coat plaster. Just fill the holes flush these boards are very hard because of the honeycomb it will be fine.
tiler
Mark B
Wetdec & Whitebeam,
Thanks for the advice.
I have just spoken with the customer and he is really keen to remove the inner plaster board, remove the centre core, construct a timber stud frame within the wall, re-board the inner skin with backer board and then screw the outer skin to the studwork. This is after he had spoken to a builder he uses who has had to do this before.
I'm not sure that's going to be the easiest option but it should provide a better substrate in the long run.
Mark.
Reply to Problem with paramount wall board :-( in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
    • Friendly
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
