Discuss problems tiling over melamine in the UK Tiling Forum area at TilersForums.com.
One Day
Hmmm, unsure about tiling to melamine. It's a pretty inert substrate and resistant to most things.
Personally I'd have used something aggressive like an S2 adhesive (BAL Fastflex or any other 2 part adhesive).
Ready mixed adhesives dry through dispersion (water loss) so it can take ages before it starts to grab and maybe up to a week (seriously!) before it starts to bond.
Deleted member 9966
as Impish says, it's the adhesive that is the problem here. you need a powdered adhesive that you have to mix yourself. powdered adhesives set by chemical reaction rather than air and water loss. but you also need to consider the preparation of the surface you want to tile on to, otherwise the tiles may continue to come off.
One Day
Thanks for the replies. I used B&Q tile and grout, it's only a small area 800 x 300 to support a wash basin on top of a melamine wall unit. I taken all the tiles off and am now thinking of puting a plywood base on it as a base for the tiles.
B&Q Tile and grout will soften when it gets wet (if it ever dries!) so it is completely unsuitable for use near a wash basin. Best as GRR says and use a cement based adhesive. I'd use BAL mosaic fix which you can buy in little bags I think. You are best using a proper grout too rather than ready mixed.
Reply to problems tiling over melamine in the UK Tiling Forum area at TilersForums.com
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
