No reason for trying to peel off.just thought I would see how well stuck.bit of a shock.Can I ask what made you take a scraper to it? I can't say I've ever tried to do that, so no idea if that's normal or not!?!
Try it next time you tank the next day.Certainly a bit of a worry!
this could be just the way it is.mira have not come back to me yet.
been using Mira without failure for 12years or more
Other thread was me and plaster wasn't over polished nor moisture in the plaster,There was another thread about peeling tanking, it was the palace stuff and the ideas was over polished plaster, moisture in the plaster etc....
I had exactly the same problem as you John, primer peeling off with the barrier paint,Try it next time you tank the next day.
the mega reps told me(used mega after palace peeled twice), "it's the way it is" scraping and pulling in a small area applies a much greater and different type of force than hanging tiles off it, so I trusted his words(maybe stupidly) but all the 8mm glass mosaics are still stuck to the wall, I also left it a few days longer to dry out than manufactures recommendations which seemed to help with adhesion
