Discuss Professional Travertine Fitter - What should I be looking for? in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi Grumpy, As it states in the british Gypsum site book; The total weight of tiles and plaster applied over a bonding agent (pva again) is limited to 20 kg, Therefore consideration should be given to tiling directly to the background. I would'nt want to be putting that weight of tiles on float and set as the finish is what the tiles are holding onto.
Hmmmm! Thanks for your reply whitebeam. Looks likee my training and notes may be wrong then.
tiler burden
i dont know how you can come to that conclusion that a wall that has been plastered to a brick back ground automatically allows 40kg/m2?? what if the brick was engineering brick or any dense format?? if you look at a backing plaster under stress, then you can see that it breaks away alot of the time before you reach the brick/blockwork. it is designed for its thermal values more than its residual strength.
you would be right if it was sand and cement render but i agree with whitebeam. if its plastered then its 20kg/m2...when i say plastered i mean any gypsum backing plaster and multi/board finish...
Reply to Professional Travertine Fitter - What should I be looking for? in the British & UK Tiling Forum area at TilersForums.com
Sorry for asking a question that I already think i know the answer to but I just need...
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
Starting to get fed up of the plastic boarding I keep seeing on walls in bathrooms and shower...
Hi I've had a leak from the shower to the room below. I thought it was likely the Silicon seal...
benchwarmer
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
