Discuss Progressive hole in porcelain tiles in the Canada Tile Advice area at TilersForums.com.
L
LM
On a side note : I know you'd Silicon the inside corners in a shower for expansion, but would you also Silicon every other internal corner in an en suite? I assume so for the reason above, just want confirmation of best practice.
All transitions in tiling should be siliconed/caulked :)
1animal1
I gathered that would be the case but wasn't sure as seen quite a few jobs where the corners had grout :)
As I'm using grey adhesive on off white tiles that will have white grout - being careful! Would I be ok back buttering then trowelling adhesive onto the tile with the notched? I only ask as the grey seems to drop everywhere when loading the wall compared to white for some reason.... And when I'm doing the top tiles, it'd be easier if I could notch the tile back instead... Thoughts?
L
LM
As long as one is notched and the other is skimmed with the flat side of the trowel then it is practically the same thing. As regards grey adhesive making a mess, it's the same problem with white adhesive, the excess still needs to be cleaned off the tile and out of the joints thoroughly anyway before grouting.
Make sure your not mixing your adhesive too wet and load it in smaller batches onto your trowel and you should find it easier to control spillage.
Reply to Progressive hole in porcelain tiles in the Canada Tile Advice area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi all, I will soon be installing the Wunda EPS 400 UFH boards in my own kitchen, approx 50m2...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
