Discuss putting tiles onto a painted surface in the British & UK Tiling Forum area at TilersForums.com.
spenny
hi guys,
got a job starting monday in a new build housing scheme(was newly built about 4 years ago) and the customer wants his existing bath to now have a shower. So, i only need to fix tiles to the top half of the wall around the bath as obvioulsy the bottom half is already tiled.
The area i need to tile onto is painted (i think its plaster underneath). My question to you all is how should i prepare the wall? I know we obviously cant go onto paint as it will just peel off, so my thoughts were that i would just apply paint stripper and then i would be alright?? I dont think fixing ply wood would be an option as it would then make then not on level with the existing tiles below.
Thanks in advance
spenny
spenny
what is biscuit back?? SOrry for my ignorance!? Im going to used tubbed ady. The tiles im using are ceramic mosaic effect tiles from topps......having never used the mosaic effect tiles before-i presume the best way to use them would be to use a small spacer fo rthe best effect?
And again excuse my total ignorance, but when you say prime the wall.............i always understood that to be making the wall as flush as possible, but am i maybe missunderstanding this?
medlar
sorry a bicuit back tile is the cheaper end of the market ...clay with a 2mm glaze on top the 1 where you can grout 2m2 at a time:grin:.i know it sounds unprofesional when i fix mosaic panel tile i use a beer mat for the joint as any bigger than 2mm the tile doesnt blend in and you see everyside to the tile
couldnt have put the description of "biscuit backed" any better myself mate
bigandy
PRIME the walls means, prime with SBR (available at all tile shops) not pva or anything else you have been told. it helps the adhesive mechanically adhere.
PREP the wall by ensuring its flat then prime
Reply to putting tiles onto a painted surface in the British & UK Tiling Forum area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    • Friendly
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
