:rant:I can understand where Redfearn tiling is coming from to a certain extent, although the manner in which it was said wasn't the best.
I am a time served tiler, never been on a course for tiling in my life.
I did a 3 month C&G course for painting & decorating in 1998, and through the years have gained more experience, more confidence, discovered better ways to do certain things and generally got better at what I do.
In life you cannot beat experience, experience is worth soo much.
A course, no matter what it is, will never teach you everything that you need to know no matter how long the course is. However a course is designed to teach you the basics, and an introduction to the core elements of the subject matter. Sometimes a course is only as good, or as bad as its teacher.
I, like most tradespeople have seen a lot of bad work, also I have seen a lot of good work too.
Many "so called" tilers, are either plumbers, builders, carpenters or just odd job men having a go, so therefore you can't criticise guys fresh from a course as being a cowboy. They are in a quandary after leaving a course.
How do you get better at tiling - experience, how do you get the experience - by doing tiling.
If you look in anywhere people are advertising their tiling services. Say for an example there are 10 adverts for tiling, garanteed half, if not most of those guys are not proper tilers, ie they do other things like plumbing etc. their day job is not tiling.
Tilers
tile, plumbers plumb, painters paint etc.
