Discuss quarry tile floor in the British & UK Tiling Forum area at TilersForums.com.
N
nathnita
Hi again
Another quarry tile question!
In the hall area(red/black tiles,6x6) most of the red are light pink/white with age/wear? most of the surface has deteriated.Black are o.k.colour.
They seem to be laid on sand-no adhesive.
Will these 'clean' up and what should I seal with bearing in mind they are direct on sand?
thanks again
Nathan
F
frankenfurter
Hi Nathan,
Any photos pal? They really do speak a 1000 words :)
The base will probably be a lime mortar that has over time deteriorated, giving the appearance of sand or compressed sand. The white could be a few things but without seeing photos it'd be guess work.
Sealing is a little dependant on how porous the tiles have become over time. Something simple like HG impregnator and HG Golvpolish is quite popular.
N
nathnita
Hi
Photos as promised attachment
Cheers
Nathan
F
frankenfurter
Hi Nathan,
Pretty small photos :) but it looks like efflorescence on the tiles, this can be removed, but it takes quite a bit of work and often in several passes. Does the floor have a history of damp? Must have been pretty damp at some stage with the lime mortar degrading to sand, any idea when it was last damp/wet?
In all honesty by time you've paid for the correct products to remove the efflorescence, clean and seal the floor, plus your time - you could get a restorer in and let them worry about it.
F
frankenfurter
This is a very simple method of trying to solve the problem, must point out that I would do it this way or use the same products, but I have the benefit of the products and equipment to be able to do it differently. So I have to advise the DIY way
Nathan, It looks like you've been removing carpet that has covered the tiles and probably prevented them from airing and drying out sufficiently.
Initially you'd be wise just to get all the old floor covering up and out the way. If there's any thick powdery white powder, vac that up and follow up with a stiff scrubbing brush. This is just to remove the old dry efflorescence that is laying on the tile, vac what comes up.
If this tactic is working but leaving some left behind then you may need to repeat.
Then I would leave the floor for a few days to air out and see if the efflorescence reappears. If the efflorescence does reappear then further investigation would be required as either there's still damp in the tiles or the mortar bed, so you'd either have to remedy the source of the damp and leave it to dry (preferred option) or apply products that inhibit the efflorescence; I've tested loads and never been impressed by any of them.
If no efflorescence reappears then again a scrubbing brush and lithofin KF victorian tile cleaner will remove a lot of the dirt, you'd be wise not to let the product dwell for too long, no more than a couple of minutes or you could reactivate the efflorescence. Work in small areas and use more than one pass.
TilingLogistics
Frankenfurter,
Have you tried Aqua Mix Eff Ex? I have had a lot of success with it in this situation!
Kev
N
nathnita
Just to add:i've just run my finger over the top and the white patches are where the tile has deteriated-the top had a coating on it, as if painted?would these tiles have originally had a top coating or the same clay? right though? I know this is more of a history question but with the experience out there...do quarries usually have a finish on them when newThanks againNathan
F
frankenfurter
Hi Nathan,
Any chance those images can be made larger? They are only an inch across on my screen, bit of a strain on my old eyes. I thought the second image showed a curled back carpet?
The tiles should be the same colour throughout. Not unheard-of for people to paint tiles though, damn loonies!
If the tiles are as old as the house, they could be laid on compressed sand, some of the churches I've worked on were sand. And tiles maybe 'winter' tiles where the clay slabs were left outside over winter to break down the internal lumps of clay. - If this the case Nathan, you be wise not to even contemplate DIY.
@Kev,
My son's a chemical scientist, he creates all our cleaning and sealing products and over the years we've tested pretty much every brand going both on new tiles, original tiles and by my son in the lab against our stuff; nothing comes close. But our products are designed for one type of tile only, they don't need to be soft and neutral like the natural stone stuff, so they'll always be more effective. But we've spent £1000's on development.
I've used EFF-Ex and though not blown away with it I find it pretty good, better than most of their range of which I only rate two items (which regard to victorian restoration)- Ultrasolv and SCR.
Cheers,
Frank
Reply to quarry tile floor in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
quarry tile floor
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
