Discuss Quarry tiles in the British & UK Tiling Forum area at TilersForums.com.
Matthew77
Hi all
I know traditionally quarry tiles were laid using sand & cement or sand & lime, but can you use a flexi adhesive like dunlop fast set?
Also do i need to seal them first as they are quite porous, if so what is the best way to do this before fixing or before grouting?
Anything else quarry tile related things I should know before laying these?
Matt
Time's Ran Out
Matt - first thing you should check is that they are Quarry tiles!
Traditional Quarries have a very low porosity level ( don't accept moisture) and are frostproof and thats why they are mainly used outside.
You can fix them with sand/cement or adhesive depending on the substrate and although the were at one time given a rub with oil, this was generally just to 'lustre' the surface.:thumbsup:
John.
Ajax123
1,213
Lincolnshire
I was always told rub linseed oil in to quarry tiles to add lustre and "seal" them. I did that on my quarries and it was ok. I placed them using the french wet bed method but i did something wrong cos they started delaminating. I going to take them up soon clean them up and re lay them.
On the ones I laid outside as front path I laid them with Wickes exterior tile addy and they have stuck like wotsit to a blanket despite rain, frost, snow and sun. Will use same stuff when I relay indoors as well unless advice from forum screams not to do so.
Reply to Quarry tiles in the British & UK Tiling Forum area at TilersForums.com
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
Please advise me on a sealer or two. I've had white porcelain tiles with light grey grout laid...
Quarry tiles
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
