Discuss Quartz Stardust Tiles 60 x 60 in the Australia Tiling Forum area at TilersForums.com.
Brenners71
Hi there, we are planning on having quartz stardust tiles fitted through the whole of the downstairs of our house, approx 80 sq.m. I keep hearing about these tiles lifting over underfloor heating that's connected to central heating system. The tiles I have found are not the cheap ones they are 97% quartz & the rest being resin. I have been told by Topps Tiles that they won't lift as not the cheap tiles from China! I have also been told by another company not suitable for Ufh! Confused.com! I called The Tile Association & they told me to have Ditra matting laid between the tile & ufh and this will prevent movement & moisture but I still am worried abut the lifting/warping as it's costing us a lot of money & I'll be devastated if it does happen. Would gratefully receive advice from you professional tilers out there!! Many thanks
Lithofin BOB
518
Hampshire
I would try and get some written assurance about if they would warp or even contact the manufacturer but if you do go ahead use a 2 part adhesive
It is important to consider the high coefficient of thermal expansion of resinagglomerated tile, this will certainly be an isue on the larger format tiles ,as above ,Consult the tilesupplier before using resin agglomerated tiles with underfloor heating systems.
Whitebeam, is there a need for more expansion joints ( smaller bays) to eleviate possible movement with these type of tiles and UHF ?
Also, dependant on the quality of resin binders of the aglomerate consult with your supplier, if you will need to seal prior to grouting , if quality is good you should be fine without. Will also depend on the chip make up of the tile, marble quartz,,granite or mix etc
Concrete guy
Buy star galaxy granite instead. It is far more fit for purpose for flooring.
If your quartz floor dulls and scratches, which it will, it is extremely difficult to refinish in place. Not impossible, but difficult. Difficult to a degree that grinding, repolishing and bringing back the finish would cost the same as buying it and refitting new.
Granite on the other hand is more easily maintained and would be entirely unaffected by underfloor heating being a volcanic rock.
Think of Quartz as a decorative product, it's fine in areas of the house that have low or easy traffic such as upstairs bathrooms. In a main thoroughfare it will look dull in a matter of months.
I was involved in the manufacture of quartz for some time. Trust me when I tell you granite is a far superior product.
Chalker
1,058
Tadcaster
Very good post Allan.:thumbsup:
m3fitter
09a0ee4362959254a64a069ad1641228.jpg 97423c41a83074d9aa2565a9937f658f.jpg these are the beasts, in Ringo Stars house in Chertsey, oh and Alan, didn't I fit the silicon quartz gloss white stuff for the Bose family in hersham for you, is it the same stuff ??
White Room
I would listen to Alan ATS on this one.
I have fitted gulf stone quartz on top of wet ufh in a small toilet, 4m2.
They say it is acceptable but what will happen also with yours it will fade with UV light & it won't look great in a few months time..
The quartz stardust state on the packaging it's is gulf stone or connected to....mine did anyway.
Reply to Quartz Stardust Tiles 60 x 60 in the Australia Tiling Forum area at TilersForums.com
Hello, I am hoping I may be able to get some advice. 2 years ago we had a new kitchen fitted and...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
Hello. I'd appreciate it if you guys could help me out here; I've been reading as many threads...
I'm a chippy, I fit a lot of kitchens and some bathrooms, inevitably I have done quite a bit of...
20K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
