Discuss Question about priming in the UK Tiling Forum area at TilersForums.com.
sabre198
replacing tiles, took off old tiles. the wall is plasterboard. its down to a smooth layer of brown paper backer (the top painted layer came off), which I've sanded any extra ripped layers down to flat.
Should I just prime over this brown paper layer with BAL apd and then fix adhesive.
The topps guy sold me some green star BAL and told me to just fix tiles using that straight on the brown paper and not to worry about priming.
Or do I rip off the brown paper all way to plaster layer and prime BAL apd from there?
thanks in advance!
sabre198
Thank you!
just one more question about the glass splashback/upstands... do you tile the area and then fix the splash/upstands to the tiles or lay the splash/upstands first, then tile to the edge of the glass splashback?
how best to make the join? tile:grout:glass or some other way
tiles are light cream, splashback is black glass 600x900 and upstands strips of 1000mm glass by about 110mm (topps tiles bought)
Reply to Question about priming in the UK Tiling Forum area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Hi all, I have a small WC about 2m2. I realise now, that I should have taken up the Chipboard...
My first big tiling job. It's a wet room and I'm at the stage where I have Marmox boards on...
Tilers Forums on FB
